Old 16-Oct-2015, 4:09 AM   #1
JBVT
Antenna Recommendation
Hi,
My report is below
http://www.tvfool.com/?option=com_wr...8e03717343eac1
I am looking to replace an existing antenna due to poor reception. I have a RCA yagi antenna mounted on a 3 ft. roof mounted pole approx 25 ft off the ground. The antenna is aimed at the transmitters, 121 degrees. My cable is approx. 75 ft. of RG6 running from the antenna to a single TV on the first floor. I have a Winegard LNA preamp. The RG6 is RCA brand and not quad shield. The cable is not grounded at this point.
Although the channels in the report show LOS, there are acres of trees and a hill in between the transmitter and antenna. I am looking for advice on how to achieve better results with an antenna system that is better suited for these conditions.
JBVT is offline   Reply With Quote
