but I don't notice any ghosting/multiple images.
That's an analog-only symptom. The signal impairments that cause those analog symptoms will cause digital reception drops out, pixelization, image freezes, etc, all depending on how the tuner was implemented.
Did you get the amplifier out of the system? That should be your first step if not already done.
The big concern is "What's out in front of the antenna to your north"? Your neighbor's house, a forest, a two story metal building, etc? The TVFool simulation does not and can not account for that type of "clutter", it assumes a path that is clean and clear and the appropriate disclaimers are there for the reading.
Have you tried placing the C2V directly in front of a window that faces north through northwest? That's how you get the best indoor reception, You can always work backwards later to where you'd "like" the antenna to be and see if it also works there.
