Old 12-Oct-2015, 1:41 PM   #5
rickbb
The CBS might be doable, but the ABC is going to require some effort. It's showing a NM of 2.1. Pretty low for reliable reception. But these are only an estimate.
My vote is a DB4 or DB8 with the reflectors removed. Removing the reflectors allows the antenna to receive channels from the front and back sides. Which in your case means from both the north and south.
You'll have to be careful if you use a preamp as you have a few close, strong signals that can cause overload to your tuners making reception worse instead of better on the weaker signals.
