Old 11-Oct-2015, 8:28 PM   #3
What other equipment will I need to split the signal to 3 TV's in the house?
Try it with just one TV first. If your TV has a signal strength indicator, it will help. Then, use a splitter. You can use two 2-way splitters in cascade to feed one longer line, and two shorter lines.
If you don't have enough signal, replace the splitter with a Channel Master 3414.
