Old 11-Oct-2015, 7:16 PM   #2
Welcome, Craig from Smiths Falls:
Thanks for the tvfool report. NNE to NE does look like the best direction. When I click on Pending in your report, CHCH on real channel 22 at 45 degrees true pops up.
Will I benefit from a preamplifier?
We don't know yet.
What channels do you need?
If it's just the Canadian channels, maybe an Antennas Direct C2V or a Winegard HD7694P aimed about 40 degrees magnetic, with a Channel Master 7778 if needed.
If you are trying for a few US channels, you will need to rotate your antenna, or use a separate antenna for them.
If you don't need CIII-TV GTN analog on real channel 2, because you have GTN on real channel 14, then you will not need a big VHF-Low antenna.
