If the top of the mast is 5 feet above the peak, and the joint at the bottom of the top section is below the bracket at the peak, that would be OK. If the top of the mast is 10 feet above the peak, it would depend upon where the joint at the bottom of the top section is located. If the joint at the bottom of the top section is above the peak, then the mast would need guy wires, which you probably don't want to mess with.
