Old 8-Oct-2015, 11:27 PM   #9
MikeBear
You will NEVER see the "Corrected" error numbers change on your Tivo, if being used with an antenna. That works for cable, but it doesn't for OTA antenna. Unless they fix the firmware.
Also, 72% 29db is the highest OTA signal level a Roamio is capable of showing at present. Compare that to 100%~ anywhere else.
Anything above 40%~ should be decodable, but from what I've seen, you need a steady level around 50-55% to stay completely locked at all times. Anything 60% and above, you are really doing well.
