I cut power from the sodium vapor lite near the antenna, removed the amp, (which turned out to be a Channel Master3044), no splitters anywhere. Here is some info from my tivo diagnostics-
With lite powered but off-daytime and amp on
13-1 72% 29db uncorr 0 cor 0
13-3 same
20-1 62% 25db 0 0
26-1 60% 25 db 0 0
39-1 42% 18 db 6 0
With lite power cut, no amp still daytime
13-1 72% 29db 0 0
13-3 72% 29db 18452 0
39-1 62% 25db 0 0
20-1 60% 24db 0 0
26-1 60% 24db 0 0
For some reason I failed to get the before numbers on 2-1 and 2-2 but after they are showing
2-1 67% 27db 150 million! uncorected but 0 corrected
2-2 67% 29db 100 million 0
Maybe there's a clue-the amp seemed to help some with the RS but not the signal strength much. We'll check tonite and see where this goes......I need to reconnect the amp and try to get numbers on 2-1 and 2-2.
