Antenna selection is fine.
Are all channels affected? What amp are you using? How often do you experience dropouts & how long do they last?
Bouncing signal strengths are usually an indication of multipath. If raising the antenna doesn't help, you will need to "walk" the roof to find a more favorable spot.
