Old 7-Oct-2015, 3:40 PM   #21
NthrnNYker
This is what the 7777 specs looked like from the CM 2006 catalog:
I was able to verify those specs when I did tests using some old model 7777s connected in cascade (series) to simulate strong signal overload.
http://www.digitalhome.ca/forum/1597002-post3490.html
Now, all we have that we can trust are the tests done by ADTech and others with the proper test equipment.
Yup, that verifies what I had heard reputed elsewhere -- the Channel master 7777 has higher gain and slightly lower noise than the 7778 (2.8 db vs. 3.0 -VHF & 2.0 db vs. 2.2 -UHF).....all things being the same, if the 7777 doesn't overdrive my tuners with the signals available in my location -- I think I will go with the 7777
Thank you !
Karl
NthrnNYker is offline   Reply With Quote
