Is there EVER a need for an FM trap on a UHF tv antenna?
If a person is using an HDB91x (91xg clone) antenna for UHF-only reception, is there EVER a need for that antenna's output to be run through an FM trap filter? Does that possibility change if it's filtered through a standard UHF/VHF UVSJ combiner, with the vhf side capped? Or if the UHF antenna is pre-amplified?
Or is an FM trap filter only ever appropriate to be installed on a VHF antenna?
