Old 6-Oct-2015, 7:27 PM   #6
Thank you.
Does the Samsung have a signal strength indicator to help you position your antenna?
My girlfriend is going to make us get cable!
Is she willing to pay for all or half of it?
You have some very strong FM transmitters only 2 miles away that might be causing interference to TV reception of CBS and ABC. See attachment.
Instead of the FM filter, you can use a HLSJ as an FM filter, common and high ports, because it will attenuate everything below channel 7 including the FM band.
http://www.nsccom.com/hlsj.aspx
There is also the possibility of tuner overload from TV and FM signals. Try an attenuator in the coax line. A splitter can be used as an attenuator; 3.5 dB for a 2-way and 7 dB for a 4-way.
or
http://www.3starinc.com/drop_in-line_attenuator.html
http://home-automation.smarthome.com...=&w=attenuator
http://mjsales.net/collections/atten...ant=1083705673
•Attenuation values 1, 3, 6, 8, 10, 12, 16, 20dB (FAM)
click on 1 dB for other values; the up and down arrows are faint
