Old 6-Oct-2015, 5:48 PM   #2
Welcome garek007:
The results with an indoor antenna are difficult to predict, because you have signal reflections bouncing around that can interfere with the direct signal. If you are willing to experiment to try to avoid the cable option, I suggest you try the Antennas Direct C2V antenna, which has a base for indoor use. It has a double loop for your UHF channels (real channels 14-51) and a dipole for VHF-High (7-13) that can be separately positioned for channels like CBS and ABC. No preamp should be needed or used.
https://www.antennasdirect.com/store...-Complete.html
http://www.bestbuy.com/site/antennas...=1218809260470
https://www.antennasdirect.com/cmss_...ickStart_f.pdf
Aim the UHF loops SE and position the dipole broadside (perpendicular to) 2 degrees magnetic. Try different indoor locations and extend the coax with an F81 adapter if necessary.
Remember the words of Dr. Phil: "If momma ain't happy, ain't nobody happy."
Because of the nesting instinct for the survival of the human race, a woman considers all areas in a home or apartment "her areas," and subject to her approval, even a "man cave."
So firstly, will a tuner improve my reception?
I don't know. What are you using to receive the signals now?
The Chromecast has been known to cause interference to VHF signals like your CBS and ABC. Keep your system simple, most women like that better.
