You need a large all-channel antenna with a medium or high gain, low noise pre-amp. Expect the antenna to be 10' wide and 10-14' long. Aim it south at the Albany stations, you probably don't need a rotor.
The trees will likely be your greatest nemesis for reliable reception, particularly on UHF channels. Avoid them to the greatest extent you can.
You likely do not need an FM Filter, none of your FM signals are calculated to be particularly strong.
Forum member Tower Guy is the engineer for WRGB and is in your area, he can tell you more about specifics if he gets a chance to see this thread.
