Old 4-Oct-2015, 3:08 PM   #15
Bigbear
Egg on my face!
Again you folks are right, wonder when I'll accept the fact.
Put my eyes on and went out with a flashlight and my cable is marked quad shielded. Will my fittings for ds-6Q fit?
Some other setup questions. My antenna is mounted on a pole that is not grounded ( according to some diagrams I've seen), bit it is a few inches into the ground. Problem?
I do have a properly installed grounding block for my co-ax.
My co-ax is zip ties to the mounting pole, is this ok?
Is regular RG6 cable ok for outdoor use?
Should I use compression fittings for in door use, or is it ok to use up my crimp connectors ( or just pitch them in the recycling bin)?
Bigbear is offline   Reply With Quote
