re: Configuring two antenna into CM Amp
My apologies. I really appreciate the help!
I purchased two antennas - the Winegard HD7694P (aimed at 230 deg. magnetic) and the Antennas Direct DB4E (aimed at 144 deg. magnetic) as you specified in your original reply to me. I have a Tablo DVR so I wanted both signals to be directed into the DVR, then Wi-Fi from the Tablo to my router, then, finally, to my Roku device. It worked like a champ and I am able to see several channels at very high resolution!
In your original reply, you mentioned as an option to purchase the Channel Master CM 3412 (or CM 3414). I went ahead and purchased the CM 3412, but I'm not certain how to configure the two incoming coax signals into the CM 3412. In addition, I'm not sure what port on the CM 3412 is used to output the signal to my Tablo DVR.
