Old 30-Sep-2015, 9:28 PM   #6
Alan909
PA-18 and Noise Test
Thank you for the information...I did the noise test with the Jeep radio on AM and did find increase in noise the closer I got to my antenna...turned everything off in the house one by one and the noise was from my TV, a new Samsung HD Plasma...My antenna is just outside of my window where the TV is 15ft high...My problem channels was from 12-1, 12-2, and 12-3...now that the weather is clearing up, slowly loosing signal on those channels...next step is to ground both coax and antenna pole to see what happens...
Do you think the PA-18 low noise antenna amp will help as well???
Alan909 is offline   Reply With Quote
