That would work, but keep in mind that a 4 output DA of either brand has less gain than a 2 output DA.
Actually, to be specific, both have about the same amount of amplification (15-16 dB) but one has only a two-way splitter while the other has a second cascade of two port splitters so as to provide four outputs.
The
net gain of each is different by about 4 dB due to the extra layer of splitting.
The requirement to use of BOTH a preamp and a distribution amp would be a rather rare occurrence and is usually only required when there are extremely long cable runs both between the pre-amp and the distribution point and again from the distribution point to the final outlet. It just isn't really needed very often.
