Old 27-Sep-2015, 5:24 PM   #2
They're right on the web site: https://www.antennasdirect.com/store...onnectors.html and are for standard rg6 low loss cable. The COAXMAX tool may be used for either standard or QS RG6.
Be advise that there are three general kinds of RG6 coax compression fittings: 1) Specified for RG6 Quad Shield, 2) Those specified for RG6 (no mention of QS), and 3) Those that claim to be for both.
If you try using type 2 (above) on QS, you'll go nuts trying to get the fitting on the coax. If you try using type 1 (above) on standard low-loss RG6 it may work or it may be too loose. TYpe 3? Don't know, as I usually get the correct fitting for what I'm working on.
