Thanks for the additional info. I will be purchasing the antenna tonight. I will reply back if I have any questions. Thanks again!
Edit: Thanks for the diagram. I purchased 2 RCA DH24SPF splitters, the Antennas Direct C2v and the FM trap you recommended. Now I just need to determine my cable runs so I can purchase some cable and run a test setup to find the best antenna position.
I need to think this one through, because running the -3.5dB loss coax to the TV needing the best signal will result in longer runs for the other 2 TVs. I may need to compromise here.
I am looking at antenna on roof to cable run to the attic, to FM trap, to splitter, the -3.5dB to a TV with a long run then the other cable form the splitter to the basement to run a TV in the basement and on the main floor. The TV with the long run mentioned is positioned high on the wall so I plan to run the cable from the attic.
