Old 24-Sep-2015, 1:57 AM   #10
The cluster ADTech was talking about is at 202 to 211 degrees. Doesn't look like much there for you.
He was asking about real channel 5 KCWX way down your list, not virtual channel 5.1 KENS because your widest element on your antenna can get channel 5 if it is strong enough.
I was hoping it would be something simple like daisy chaining two antenna’s. Point one to KMYS and connect to my existing antenna. Distance between would be roughly 6 feet.
Would a combiner work in this situation?
Probably not, but you are welcome to try it. If we thought it had a good chance of working, we would have suggested it already.
This is the question you asked:
What is the best option for receiving a strong signal for KMYS?
And that's the question we are trying to answer.
It's real simple:
KMYS is in a different direction, and that's where you must aim an antenna, especially with the tree problem.
I told you what your choices are in post #8; you now get to decide which one you are going to do.
It's really hard to tell you what to do because we can't see what your location looks like; we only know what you have told us.
It would help if you showed us a photo of the view toward the KMYS where your antenna would be aimed.
