Old 24-Sep-2015, 1:21 AM   #3
ngs428
Thanks for the reply @rabbit73.
I am using my 1650 without the amplifier. I used it initially, but removed it, tested and did not see that it improved anything. I am getting the following signal strengths with my 1650 per my Panasonic TV: Channel 7 - 85%, Channel 9 - 100%, Channel 20 - 100%, Channel 27 - 50%, Channel 55.1 - 25%.
As reported WFXS-DT 55.1 is not correct on the report. It was reported to be changed at http://forum.tvfool.com/showthread.php?t=15656. It is now broadcasting at low power 15kW which is why my signal is so weak.
3 questions:
1) Is there any downside to using the FM filter? I can certainly try it.
2) Could you comment on performance of an antenna in an attic where there will be snow on the roof (a foot or more) vs the roof mounted antenna where snow may get on it during heavy snowfalls. I am not sure what the better situation is for reception.
3) One other consideration is cable length. I would have about a 65, 35 and 100 foot run from an outside antenna to the 3 tvs. Concerns with signal loss on those runs?
I think I am going to try the Antennas Direct C2V based on your recommendation. Thanks!
ngs428 is offline   Reply With Quote
