Old 24-Sep-2015, 1:12 AM   #9
SanAntenna
The channels I can receive from the cluster mentioned are 17, 23, 24 and 29. Channel 29 Fox is the only one that I care about. Channel 5.1 is local KENS (CBS). The location is probably adding to the low signal. There are tall trees in that direction. Some days KMYS is fairly reliable. Other days not so much.
I was hoping it would be something simple like daisy chaining two antenna’s. Point one to KMYS and connect to my existing antenna. Distance between would be roughly 6 feet.
Would a combiner work in this situation?
SanAntenna is offline   Reply With Quote
