Old 23-Sep-2015, 8:41 PM   #2
Are you using the 1650 with or without the amplifier?
http://www.rcaantennas.net/docs/comm...NT1650F_OM.pdf
You have some very strong TV and FM signals that might cause overload to a preamp or tuner. Of course, the signals are weaker inside, so some experiments are needed. See attachment. An FM filter might be needed.
I suggest you try a temporary setup of an RCA ANT751 or Antennas Direct C2V in the attic aimed at 169 degrees magnetic to see how it does. Don't drill any holes yet.
https://www.antennasdirect.com/store...-Complete.html
http://www.bestbuy.com/site/antennas...=1218809260470
The VHF "V" dipole of the C2V should be aimed broadside (perpendicular) to 197 for 7 and 9.
I do see a lot of trees in your area, so you need to try different locations, maybe the SE corner first.
If the attic doesn't work, go outside.
