Old 23-Sep-2015, 7:12 PM   #4
I'm considering the Winegard LNA 200 Boost amplifier.
A preamp would be overloaded by your very strong signals.
I tried that. I had read on one of the posts to do this. I picked up KMYS with a strong signal. However, the other channels lost strength and pixelate. As an FYI my Samsung TV with the current antenna direction gets 5 out 5 bars on signal strength. KMYS is 3 of 5 bars. Fades in and out.
Then you will need to use your two antenna idea, with an RCA ANT751 aimed at 278 degrees magnetic for KMYS. Use an A/B switch to select which antenna you want, because two UHF antennas are not easily combined.
