Old 23-Sep-2015, 4:40 AM   #1
ngs428
Antenna Options for My Location
hello,
My TV Fool TV signal analysis can be found at the link below,
http://www.tvfool.com/?option=com_wr...8e03129473c235
I have a single story house which is 2.9 to 13.65 miles from the CBS, NBC, ABC, FOX and PBS towers as you can see from the report linked above. I would like to run OTA to 2 TVs on the main floor and one in the basement.
I have a RCA ANT1650F in one of my first floor rooms. After repositioning quite a bit I am able to get all channels in green on my report. NBC (W27AU-D) is the most difficult to get in. The reception is hit and miss in my basement with the Zenith ZHDTV1 antenna I have.
I would like to get all channels in green on my report. I am willing to install an outdoor or attic antenna if that will help my situation. I am in WI, so how much will snow impact a roof installed antenna? I do not have a direct line of sight to the close towers, there are some tall trees in my back yard.
What are good install location options and antenna recommendations for my situation? Thanks for your help.
ngs428 is offline   Reply With Quote
