Old 21-Sep-2015, 2:50 AM   #5
Swap the CM antenna for a CM preamp (either one) and swap the WG amp for a WG 7697 or 7698 and you'd have a good combination. As it is, you've got the mediocre choice of both company's products for your particular situation.
I agree that the Winegard HD7697 or 7698 with a CM 7777 or 7778 would be better for you.
The 7698 antenna has more gain than the 7697, but it is bigger.
The 7777 preamp has more gain than the 7778, but it is more easily overloaded.
Only 12 ft high?
Any trees or buildings in the way?
