One thing I've learned is that some locations simply are not fixable. Keep that in mind.
My suggestion would be to either gang two 91XGs side by side or swap it for a DB8e. I'd also dump the Winegard amp and replace it with something with a lower noise figure and superior overload resistance. If we had our Juice available, that would be the suggested amp. However, since it's out of stock for a while, my second choice would be to re-purpose an Electroline EDA2100 distribution amp in a mast-mounted, remote powered configuration. It has a very good noise figure and you won't overload it. As a matter of fact, I'd probably do that first.
