Old 20-Sep-2015, 6:56 PM   #1
madball1130
Poor reception on one TV after splitting signal
My antenna is a Channel Master CM-4228HD mounted on my roof. I have a Winegard LNA-200 Boost amplifying the signal. In my house after the power inserter if have a 2-way signal splitter to send the signal to my two tv's. When I use the splitter TV A gets great signals on all channels while TV B has good signal on all channels except two. If I remove the splitter and connect TV B directly to the feed it gets good signal on all channels. I need some suggestions on what I should do. Do I need a different amplifier?
TVFool report: http://www.tvfool.com/?option=com_wr...8e03a2a10910b0
madball1130 is offline   Reply With Quote
