Old 20-Sep-2015, 3:48 AM   #16
sau818
Ok, this is the latest. I bought the available Channel Master 7778 and tested it, The results were after coming home and the storm is gone and clear outside. RCA preamp 80 channels and the Channel Master 24 with not much on the furthest TV. So then I hooked up a Channel Master Extreme 75 stood it on the deck and received 86 channels the most ever. I then put the Extreme antenna on the pole below other old antenna and removed the RCA preamp and connected to Extreme antenna and to TV. The furthest TV just scanned 74 channels including CBS Chicago. The main TV scans 79 with RCA amp. We will see what tomm brings but for now I have CBS on every TV in the house. If I have a problem with the far TV again and the first TV still works good with this Extreme antenna I will just buy another Extreme antenna and eliminate some of the cable runs and splitters. In fact if this works during the rain I will buy another one for my detached garage!!!!!!!!!!!!!
sau818 is offline   Reply With Quote
