CBS in the Quad Cities is on low band channel 4 with a weak signal for low band. That will require a Winegard 8200U or HD 7084P mounted as high as possible. That antenna will also get the UHF stations in the same direction. For only the UHF stations at 323 degrees a 91 XG would do fine. You can't use a preamp at your location.
