Old 19-Sep-2015, 3:11 PM   #4
BrooklinOTA
It might in Whitby, ON, Canada, where you are located, but it wouldn't satisfy the requirements of the NEC here in the US.
The code here says the coax shield should be grounded with a grounding block that is connected to the house electrical system ground with 10 gauge copper wire for electrical safety and to reject interference. For further compliance with the electrical code (NEC), the mast should also be grounded in a similar manner to drain any buildup of static charge, but the system will not survive a direct strike.
So, when you say the antenna was grounded at the fuse box, do you mean the mast and the coax were grounded there or only the coax?
Based on my experience, the first thing to do is to ground the coax with a grounding block connected to the house electrical system ground for electrical safety to protect you from electrical shock.
An example:
Getting A/C voltage on converter box's antenna input !
http://www.digitalhome.ca/forum/81-o...ml#post1457594
Equipment Leakage Current
http://www.digitalhome.ca/forum/81-o...ml#post1457668
There is a grounding thread on the Canadian DHC forum:
Grounding OTA / Dish / CATV / Telecom - See Post 1
http://www.digitalhome.ca/forum/15-h...-post-1-a.html
Originally Posted by Greenish Apple View Post
The original installation is not even code in Ontario Canada. It's probably the misinterpretation of the code/shortcut by the installer.
As rabbit73 shows, it should have a ground rod outside and a connection to the electrical service panel. But I've read (various threads) that 10AWG goes to the ground rod & grounding block and 6AWG goes from the rod to the panel.
GA
Thanks for the help. All I have right now is the coax grounded to the house electrical system ground through a copper wire. In other words the copper wire is going from the screw at the splitter (where the coax from outside splits to the 2 TVs) to the house electrical system ground all at my fuse box in the basement.
BrooklinOTA is offline   Reply With Quote
