Old 19-Sep-2015, 2:49 PM   #3
Greenish Apple
The original installation is not even code in Ontario Canada. It's probably the misinterpretation of the code/shortcut by the installer.
As rabbit73 shows, it should have a ground rod outside and a connection to the electrical service panel. But I've read (various threads) that 10AWG goes to the ground rod & grounding block and 6AWG goes from the rod to the panel.
GA
Greenish Apple is offline   Reply With Quote
