The FM Fool side of the site doesn't provide detail links, you have to provide the image of your display.
What specific FM stations are on your list for FM?
If you have strong and weak FM signals which are desired and weak TV signals that will require amplification. it is strongly recommended to use a separate antenna for FM, reject any FM from the TV antenna, then combine the signals into a common distribution network AFTER the amplifier does it's job for the TV signals. This will entail some increased complexity and may involve customized components.
