Old 18-Sep-2015, 10:03 PM   #25
I have not gotten the pre amp yet, but I am buying the channel master cm7777 and will be mounting on the mast with the antenna. From reading it seems I will run a short rj6 from antenna to preamp then more cable to basement where I will have the power inserter then into splitter.
That's correct, except the coax is RG6.
What are some opinions on the channel master antenna's I am currently leaning toward the wineguard as suggested in this thread
We have been talking about Channel Master amps, but I didn't know you were thinking about Channel Master antennas.
