Old 18-Sep-2015, 9:41 PM   #7
Stereocraig
Originally Posted by berbes View Post
hello ad tech,
will the vhs add-on give me enough umph to get ch 2 chicago? it's the hardest one to dial in unless you're in the same bldg they broadcast from. finally, how high can i run the pole? i know the higher the better, but after a certain length, (it's also mounted in a rotator) the antenna will sway too much, right?
thanks!
FWIW, I must be lucky, because I've never had any problem w/ WBBM real 12 and I use a 91XG for that one, at 46 mi.
Yes, the mast will be more susceptible to sway.
Additionally, you'll want to achieve your height, below the rotor.
Keep the stub above the rotor, as short as possible, w/o interfering w/ your coax loop.
