Old 18-Sep-2015, 5:50 PM   #24
agmccall
Which preamp did you get and where will it be located?
You don't need a rotator because all the signals for you are in the same direction. And you don't want a rotator because:
1. You don't want to rescan after every change of direction
2. Who gets to decide the direction when more than one TV is being used?
3. Do you really want to wait for the rotator to swing around?
4. Do you want to go up on the roof in January to fix a defective rotator?
I have not gotten the pre amp yet, but I am buying the channel master cm7777 and will be mounting on the mast with the antenna. From reading it seems I will run a short rj6 from antenna to preamp then more cable to basement where I will have the power inserter then into splitter.
What are some opinions on the channel master antenna's I am currently leaning toward the wineguard as suggested in this thread
thanks
al
agmccall is offline   Reply With Quote
