Old 18-Sep-2015, 3:09 PM   #2
It looks like channel 11 wluk, which is one I'd like, is a vhf channel?
WLUK is the only station in Green Bay that chose to stay on VHF.
Will a uhf antenna pick this up?
Sometimes. It's pretty much impossible to predict accurately. It is usually best to PLAN for VHF reception rather than to rely on chance.
but the signal would have to pass through a brick exterior wall.
Brick veneers often have a rebar support system hidden in there. The steel tends to do nasty things to incoming signals making a mounting location behind them questionable.
Is there any spot in your attic, based on your home's physical orientation, that offers a "view" through either a non-bricked dormer or only the roof deck in the direction of GB? If so, an attic install might work out.
I also have a base and pole still on the roof from years back that would afford me 40' of height.
Probably a more desirable location as long as it doesn't cause the antenna, when aimed at Green Bay, to be facing point blank into a building, a big tree, or a forest.
No rotor is needed, Green Bay is your only required aiming direction.
