Old 18-Sep-2015, 1:43 PM   #1
jebermi
cable cutter newbie needs antenna advice
Hey all. I ran the signal analysis for my location and am confused about the channels I'll get with the right antenna. It looks like channel 11 wluk, which is one I'd like, is a vhf channel? Will a uhf antenna pick this up? Everything else looks to be uhf although a couple stations I'm not familiar with don't say. Here's the report:
http://www.tvfool.com/?option=com_wr...8e03ba46af452f
I have a tall house and would prefer to put the antenna in the attic if possible. There's plenty of room for the largest antennas up there and I think I could even use a rotor if need be. The height there would be about 30' but the signal would have to pass through a brick exterior wall. I also have a base and pole still on the roof from years back that would afford me 40' of height.
Some of the stations appear to be repeats of others. No point in that. I'd like as many unique ones as possible. I looked at antennas and if I chose one it would just be a guess, probably a bad one at that. BTW, there's really no one in the business around here to ask any longer. I'd sure appreciate any advice or help. Thanks in advance.
jebermi is offline   Reply With Quote
