Old 17-Sep-2015, 11:17 PM   #4
How does that work for a pad based/installed pole?
Interesting question in the gray area between the usual two ways. The diagram shows that the grounding block and the mast should be grounded separately to the house electrical system ground. The other way it is done is to connect the coax grounding block to the house electrical system ground and connect the mast to a grounding rod below the mast. In the second case the code says that the grounding rod for the mast must be connected ("bonded") to the house electrical system ground with number 6 gauge copper wire, which is very expensive. The reason given is to eliminate any difference in potential between the house electrical system ground and the mast grounding rod.
I'm not certain which category your ground mounted mast falls in, but I would pick the less expensive way. Since you have a lot of storms in your part of the country, you might want to consult an electrician. The person who has the final say about an electrical installation is the local electrical inspector, who the code calls the AHJ, Authority Having Jurisdiction. You might not want to get the inspector involved because some are more friendly than others. A local electrician can tell you more.
Todd Humphrey doesn't speak for the NFPA that publishes the NEC code, but he has some ideas that are helpful.
Satellite System Grounding
Part 2 - NEC Overview
Presented by Todd Humphrey
http://www.reeve.com/Documents/Artic...ents_Reeve.pdf
I see that Antennas Direct DB4e is cheaper online but then returns could be cost prohibitive if reception is a problem....
I understand your problem, but I can't guarantee results because too many unknown factors are involved. I picked the DB4e because it has more than enough gain for outside, and might have enough for the attic. You don't need a preamp for outside, but if the attic loss is more than average, you could add an amp.
BestBuy sells Antennas Direct antennas.
