hello ad tech,
will the vhs add-on give me enough umph to get ch 2 chicago? it's the hardest one to dial in unless you're in the same bldg they broadcast from. finally, how high can i run the pole? i know the higher the better, but after a certain length, (it's also mounted in a rotator) the antenna will sway too much, right?
thanks!
