Old 17-Sep-2015, 8:53 PM   #3
Tempus T
Thanks for the reply
rabbit73>
Nothing in the way to the ESE just those wonder pines to the north.
The idea of putting it in the attic is appealing, if it works of course.
I will have to look into the whole grounding part of this. How does that work for a pad based/installed pole? I see by the diagram that the mast is grounded from a clamp mounted around(?) the mast pole so does that mean it would just be run down through a clamp on the in-ground pole? Of course I'm not even sure where/what the "power service grounding electrode system" is. But yes I figured it would be important, especially down here.... Is there a link to more grounding instructions on the site that I'm not seeing atm?
I see that Antennas Direct DB4e is cheaper online but then returns could be cost prohibitive if reception is a problem....
Decisions Decisions....
Thanks again for the reply!
Tempus T is offline   Reply With Quote
