Old 14-Sep-2015, 4:27 PM   #9
DennisC
Rabbit73
Sorry for the delay in responding. Ok, the Winegard YA 1713 Prostar 1000 10 EI, HI band VHF antenna (on top of pole) is currently aimed at about 157 degrees. The Antennacraft U8000 8-bay UHF antenna is difficult to measure the aiming direction although it is about 170 degrees. After being mounted for four years they may have moved some and may need to be re-aimed. The two antennas are combined with a UVSJ device. Yes the U8000 was modified to make it bi-directional by removing the reflector rods. The main difference in reception now compared to the past is that I am not getting the local PBS on a dependable basis and would like to fix that if possible.
DennisC is offline   Reply With Quote
