Old 14-Sep-2015, 2:32 PM   #22
Regarding the pre-amp How long is the electrical cord as I will probably need to add to it because where the antenna will be mounted I would either have to drill into the house or run it along the coax to the basement. Will there be a problem with interference if the power cable for the preamp and the coax from the antenna are run together down the side of the house.
That's all unnecessary. Preview the installation instructions for the pre-amp to see how they're connected.
