Old 14-Sep-2015, 1:21 PM   #21
agmccall
Thanks again. I think I am ready to go. just a couple more questions.
Regarding the pre-amp How long is the electrical cord as I will probably need to add to it because where the antenna will be mounted I would either have to drill into the house or run it along the coax to the basement. Will there be a problem with interference if the power cable for the preamp and the coax from the antenna are run together down the side of the house.
And lastly, what are your thoughts and opinions regarding adding a antenna rotar to this system.
Thanks
al
agmccall is offline   Reply With Quote
