Old 12-Sep-2015, 1:40 AM   #26
Irata
Thank you for the documentation rabbit73.
How high can the mast be on a ground mount (if I missed that in the PDF I apologize)? I've attached a picture of the side of my house. I was thinking that a ground mount could be closer to the actual entry point to shorten the coax run. The gas line may be a problem as I currently do not know where the utility comes in from. The biggest concern of mine would be mounting that close to the electrical lines coming to the house and whether that is safe or not.
If you look in the distance you can see the tower my neighbor may or may not be willing to part with for free.
Irata is offline   Reply With Quote
