Old 11-Sep-2015, 9:19 PM   #2
Hello, Bill:
The ANT751 doesn't have enough gain for your signals. NBC has a Noise Margin of only 8.7 dB. I suggest a larger antenna like the Winegard HD7697P aimed at 221 degrees magnetic by a real pocket compass and a Channel Master 7778 preamp.
The splitter goes after the power inserter. If you need more signal substitute a Channel Master 3414 amp for the splitter.
