Thread: Antenna options
Old 9-Sep-2015, 7:08 PM   #81
i came across this
Cleansweep 10A
While i think something like this may work i cannot find any prices on them.
Why don't you call them and ask what model might help you:
http://www.onfilter.com/
I mentioned this earlier. What did you think of it?
http://www.newegg.com/Product/Produc...w&gclsrc=aw.ds
The ISOBAR has a filter and a good reputation. The only problem I had with mine was that I had to make sure I turned the switch on and off quickly otherwise it would arc and damage the switch contacts. The PC SMPS power supply draws a lot of current at turn-on. My fix was to solder the internal switch on and insert a heavy duty motor starting switch in the cord.
Nicholas Goss had a difficult EMI problem:
Signal interference from air conditioner help please
http://www.avsforum.com/forum/25-hdt...lp-please.html
