Old 9-Sep-2015, 8:11 AM   #4
Stereocraig
I wouldn't be too concerned about the first two pair, cause they're for the lowest VHF stations. I would carefully try to straighten out that bent one, though.
You may want to replace your coax and balun and seal the connections, w/ Coax Seal. For starters, maybe just clean up the fittings and screw terminals, to get an idea where you stand.
Those vines may tangle up your rig eventually, too.
