Old 9-Sep-2015, 1:24 AM   #16
olnick
You are correct in all your statements! As to the test set up.
On Wednesday I plan to pull the antenna down, check all the connections for water entry Etc. I will do a sig strength reading from the antenna down as I replace the pieces back into the circuit.
Thanks
Olnick
olnick is offline   Reply With Quote
